fatwreck
- ottawa, il
I'm starting to put my waggy 44 together. I got the coil buckets and one lower control arm mount done.
On the driver's side though....the spring perch for the waggy leaf springs is in the way. I'll probably grind that down some and modify my control arm mount a little to fix it, but what a pain in my arse. :wierd:
On a side note, I don't think that I am going to go with a hi-steer setup. I will probably run my draglink over to the passenger knuckle though. With this setup will I need to move my trackbar to the top of the axle?
