If you move the switch to MAX, BI-LEVEL, or that other one, then yes, that is normal cause your kicking on your AC Compressor. This also occurs when you use the defrost setting.
You should not see a voltage drop with the fan off and the switch on HEAT
Also if you have the fan off, might as well move the switch to off too, makes sense to me.
