- Houston, Tx
If you have amazon prime you can get em cheap shipped in 2 days
Just to be clear, you don't want to use the ZJ drag link, someone ran into issues using one of those recently, though I'm not sure how it caused them. QUOTE]
What issues did you come up with Ive been running my zj tre for 1.5 year or so and 4.5 lift just wondering what you had happen?
There is nothing wrong with using the zj draglink but its also not required. It's the same as the xj draglink on mid 90's and up.
http://naxja.org/forum/showthread.php?t=1089852
Take this with a grain of salt, as I have never heard anything about anyone else having an issue with the v8 zj drag link... personally I would just use the xj one since it is just as strong and obviously does not cause issues.
Yes it (DS1238) will be an upgrade for a 84-90 xj. The DS1238 is from a 91-01 XJ. Just a side note a (not on my list) DS1311 is for a v6 grand from 93-98, and a DS1310 is from a v8 grand from 93-98. The only diff I can see in the DS1311, DS1310 from the DS1238 is a slight bend(not much) at the sleeve end on the DS1311 and DS1310 and they are about 3/4" longer at the sleeve end then the DS1238 is. The distances between the TRE and the first hole(were the DS1312 mounts in) and from the first hole to the stabilizer hole are identical on all three pieces. enjoy
Mine are from O'Reillys also. Im kinda bias though as I am management at O'Reillys in Houston(by 45 and 1960 area)
Here are the part # I used for mine. They were all moog parts aswell
1 #DS1312 long tie rod, its solid not hollow
1 #DS1238 drag link
2 #ES3096L short tie rod ends(1 by pitman, 1 by outer driver side)
2 #ES2079S adjustment sleeves
The DS1238 will not be an upgrade for you if you are wanting to put it on the 2000 XJ you have in your profile. DS1238 is your stock replacement. You already have that one on your XJ. DS1238 was stock from 91-01 year models. It is an XJ part not a ZJ(grand Cherokee) part.
I'll get a pic tomorrow if Mikegronholz doesn't beat me to it. Here are the walk in prices from O'Reillys all moog's
DS1312 $64.99
DS1238 $100.99
ES3096L $35.99 each
ES2079S $20.99 each
total of $279.94 to do it all (1-DS1312, 1-DS1238, 2-ES3096L, 2-ES2079S)
total of $121.97 with out the drag link setup (1-DS1312, 1-ES3096L, 1-ES2079S)
plus tax if applicable
