- Salem, OR
the other day I was doing a alignment on my xj and noticed that the drag link connecting to the pitman arm had the same size shaft as my zj tie rod. I know the stock tie rod on the pitman is kinda dinky, was wondering if anyone has tried swapping it out to a zj tie rod with the zj sleeve? Would it work? Would the pitman need to be drilled out?
