Looks familiar. I remember that night.:laugh3:
You do huh..... well how many beers did we drink?
doing a dana44 is definitly more expensive, my friend got quoted at $500 for having it set up to run on the xj (waggy 44) and then another $600 for gearing. So $1100, yet i just found a 4.56 geared dana 30 for $75... hmm bit of a price difference there...
The HP D30 is only worth a little bit of polish... Not a lot.
Here is what I did I had a plate welded to the upper mount on the passenger side
JKS mini skids welded on
Now for the pricey part 4.88 and an ARB.
I did this for a final goal of 33-34 inch tires. I have no interest in bigger I wanted better than stock grunt hence the 4.88 instead of 4.56.
I am now just getting it under the Jeep so I will let you know how it goes
if i were to do it all over again, id done a D44 up front. if you have the skills to put a truss on (or in my case paid someone to do it) its not much harder to put the coil mounts and the LCA mounts on. lower gears woulda been awesome...oh well you live and learn. heres mine though:
I would disagree. I polished the shit out of my 30 and have been flogging it for almost three years now without an issue... and I am *really* hard on my junk.
I am glad for you and I feel better about putting some polish on my D30.
However well built, it will not be as strong as a HP D44. I would dare say that your built axle is as strong as an LP D44
I went with the D30 for the budget reasons that my brakes, and steering could remain unchanged. for now...I also went with the 27 spline ARB for 2 reasons.
1) I do not want the ring and pinion to be weaker than the axle shafts.
stock shafts with either 297 or 760 joints will (should) blow before the ring and pinion. When the ring gear/pinion blows your day is done... crappy, yes but a shaft can be replaced in short order.
2) stock shafts can be had for cheap and at any scrap yard.
Those all look awesome and I am really starting to figure out what my plans are for it. While Im at it I will definitely get rid of the utk steering and most likely go with a WJ style setup such as Cal's. Sucks b/c this is my dd and I cannot easily start building this while dd'ing my Jeep. I will be running no larger than 35's so I think I will stick with a hp30. If anything changes after that it will be in the very far future...
