Unibody Frame Cracks at the Steering Box
cracker said:
I would like to drill out the end of the crack and rosette the drilled hole and finish by welding the rest of the crack. I am also thinking about plating the whole underside of the framerail and the portion between the JKS plate and the track bar bracket. I would like to actually weld it TO the track bar bracket.
Do you see any problems with plating the underside and welding to the track bar bracket?
No problem, do it just the way you are saying.
