XJ Stryker
WHO DAT!
- Smiths Station, Al
Potluck!! Forgot about that. Since I will be arriving T-day I think some Walmart chicken wings are in order so they will be hot.
Buahahahaha!Potluck!! Forgot about that. Since I will be arriving T-day I think some Walmart chicken wings are in order so they will be hot.
Buahahahaha!
You've never been to Attica have you.......
At least a few sips anyway....Unwritten rule #69 even Hale drinks at the camp fire.
I take it there is no Walmart close by hmmmm. Hope yall like pop-tarts
for reference how does the green trail compare to oh..... say trail 21 at redbird? When you say be ready for damage are you talking body damage or worse? I don't really mind too much about body damage after redbird in august. I am driving it there and back so i don't want to smash a rock up into my t-case or something worse!![]()
What are you bringing to the potluck Friday night BOB?
:illegalflipoffsmilie:
21 is far worse than Green. Green would equal roughly half the difficulity of 21. You'll be fine on green, no doubt.
As for body damage. It's always a possibility. If you watch yourself on on green it should be avoidable(for the most part, depending on weather and trail conditions) however, no whining if it does happen......like I said it's always a possibility.
I think I'll probably run green at least once just to hang with the noobs. It's been a while since I've ran it. Maybe I'll see if I can get through it in 2wd.![]()
Yeah she is small. I should have sliders by then though!depending on how your Heep is set-up and how you drive, damage is possible. There are some areas on green, that without the right set-up, you can get damage. There are some by-passes in some areas that can help get you around some damage prone areas.
BOB
Sliders will be good. I tweeked my rockers at my 1st WF....no sliders. I had 3" lift on 30's and hit the rockers on one of those lil' steep hills when I crested it.Yeah she is small. I should have sliders by then though!
If you are worried about body damage cut it off.....
BOB
