Should be any easy one here....
Hoping to stock up on trail repair parts.
I have a 95 XJ, D30/D35 with the 4.0 and ABS.
I believe the u-joints on the front axles shafts are the no-longer available 5-297X ones which can be replaced with 1310s, Is this true?
Also, the stock u-joints for the front driveshaft, are these able to be reaplced with 1310s.
I recently replaced the double cardon joint on my rear driveshaft (powerdrive shaft installed with my lift kit) and used 1310s for those, but did not replace the u-joint at the rear axle. I'm assuming that the rear axle u-joint is also suitable for replacement with a 1310.
Ideally, they are all the same and I can carry a few 1310s and be covered.
