IntrepidXJ
NAXJA Member #647
- Grand Junction, CO
Blaine B. said:That's a bit odd on the fitment. I don't think my friend had that trouble when they were welded on his C8.25.
Hmm...
that's because the 8.25 uses 3" tubes
Hmm...
uncc civilengineer said:4. Please again show me a quality spring perch that's longer...
IntrepidXJ said:http://www.ruffstuffspecialties.com/catalog/standard-spring-p-25.html
$29
I got nothing against the UBE's.....I'd just rather save the money for something else.
uncc civilengineer said:Yes but you gain little if any lift from these...
IntrepidXJ said:i understand that....i was just answering your #4 question...nothing else
bobnoxious said:Dude, take your name calling and stick it up your arse. Grow up, and act like an adult just this once.
I should re-qualify that...only on 3+ inch axle tubes do they fit without having to fill a huge gap.
Here you go, here's how they fit on a D44...
This is a crappy fit. Period. Saying it's not doesn't make it untrue...it just means you freak:rattle: any time someone says something bad about the product you decided to have a big friggin boner about. BTW, my welds attaching those pieces of crap to the axle are better than theirs also.
ROBERTK said:All I can say is that your the one that made a filler piece instead of just taking a grinder or flap wheel to the arc.. :laugh2: :laugh2: :laugh2:
Now that right there is some shade tree logic.. :farmer:
jeep/bronco said:i myself dont like the idea of them being welded on very much but why could you not use the plates with u bolts doesnt look like it would be a problem and then you have the best of both worlds it is truly adjustable and you are not relying on your welding skills to hold up
you're spring perches still have to be welded when you're using u-bolts, other wise the axle will spin.jeep/bronco said:i myself dont like the idea of them being welded on very much but why could you not use the plates with u bolts doesnt look like it would be a problem and then you have the best of both worlds it is truly adjustable and you are not relying on your welding skills to hold up
im aware they are ubolt ELIMINATORS but it seems to me replacing your stock ubolts with some nice grade 8 bolts and building a slightly wider perch so that you can still utilize ubolts and gain lift without using blocks and creating axle wrap basically something like this but use u bolts instead of regular boltsROBERTK said:Whoa...
Your kidding right?
:wow:
:doh:
I know exactly what you're saying, and I just told you why it wouldn't work. Unless the perches are welded, your axle will spin inside the u-bolts. You'll break your u-joint, fawk up the yoke and overall just have a really bad day.jeep/bronco said:im aware they are ubolt ELIMINATORS but it seems to me replacing your stock ubolts with some nice grade 8 bolts and building a slightly wider perch so that you can still utilize ubolts and gain lift without using blocks and creating axle wrap basically something like this but use u bolts instead of regular bolts
ECKSJAY said:Is anyone actually running them? hone:
