two 3/4" Misalignment spacers for heim joints
mack
gone fishin....
i have a set of TWO standard misalignment spacers for one 3/4" heim joint/Rod end at a price that cannot be beat. These are CNC machined from 303 stainless steel to resist corrosion. These will give you more degrees of misalignment by spacing the joint from the mounting surface. By adding the spacers you will avoid rapid failure of the joints and add more degrees of deflection. These are especially helpful on steering and suspension applications where the ball must be articulated past the heims original capacity and for clearing mounting tabs on suspension. $10.00 shipped!
i also have a skyjacker drop pitman arm thats already drilled out to 3/4" for $30
