ert01
- Edmonton, Alberta
Info:
I am running 8" travel FOA 2" smoothbody shocks on all 4 corners of my Jeep... these shocks have the heim ends in them rather then rubber bushings.
Custom made mount on the axle end and a bar-pin-eliminator setup on the top end of the front shocks (both are double shear mounts).
Rears are using a Cross Enterprises rear shock hoop at the top and the raised Cross Enterprises shock mounts on the axle end (both are single shear mounts).
I am using misalignment spacers on all 4 shocks, top and bottom.
The Issue:
When I originally installed them, everything was tight and smooth and wonderful. Now I have about 50 000km on them (mixed on/offroad) and all 4 shocks clunk A LOT! I have tightened the mounting bolts as much as humanly possible with a big breaker bar and that keeps it quiet for maybe a day or two... then everything is noisy again.
I climbed under there and watched while my brother jumped on the bumper and I can see movement in the mounting bolts... it seems to wiggle in the misalignment spacers... as though the spacers have wallowed out and they're a bit too loose now.
My question is, is this normal for shocks with heims? Do I need to replace misalignment spacers every year? Or is this a symptom or a different issue altogether?
Also, if this is normal wear and tear, how do I prevent it from happening? I assume just check the torque on all the mounting bolts but maybe someone has a fancy trick I don't know about... tying the bolts in place or something with wire?
The Issue:
