I've noticed some things with your list. Let me see if I can help.
1.turbo
2.wstegate
- Are you going internal or external? An internal will make it easier and cheaper to sell a kit, but an external will help power and allow a more stable boost curve. If your going external, I'd reccomend a Tial 38mm.
3.charge piping
- Your going to want to include a BOV with the kit.
4.exhaust tubing
5.rise rate fuel regulator
6.drill bit for oil feed line
7.tap for oil feed line
- You don't need to tap a hole for the oil feed line. Simply run a 1/8npt Tee off the oil sender port, and run a 3an line to the turbo.
8.timing light
- I'm not sure why, but you don't need to include one. I hope your not planning on retarding base timing. Not only would the motor not like that, but the ECU will freak out.
9.oil feed lines and t
10.oil filter relocation kit
- You don't need to relocate the filter, unless your doing this solely for fitment purposes.
11.bolts
12.spark plugs
- Definetly make sure they are 1 heat range colder.
I think your kit is a great start, but I think you'll find your going to need to include more than what you thought (so people don't blow it up, and blame you). Because of this, I'm willing to bet your going to need to sell the kit for over $2,000 if you'd like to make any real profit. I highly highly highly reccomend including the split second FTC1, or a MSD BTM with the kit.
BTW, heres some pics if your interested...
My personal CRX (350whp time attack race car). It has a twin scrowl ball bearing Garrett GT30/40.
A customer's 600whp street car:
A customer's 10 second, stock block race car:
If you need any help, you can definetly PM or email me.
