Well, I started reviewing flow maps again, and realized I didn't take into account pressure change from heat. I made two calculations, at 6lbs and 8lbs of boost.
Based on this website:
http://www.turbomustangs.com/turbotech/main.htm
6lbs: 20.7 / 14.7 = 1.41 PR
at 75F there was 53F increase in temp from pressure increase. If I factor in 70% efficency of compressor this increase 53 to 76F. 75F ambient temp + 76 increase = 151F intake charge, no intercooler. This means at 6lbs of boost(PR 1.41) the density is
(535R / 611R) * (1.41 PR) = 1.24 Density ratio. With the engine at 85VE, max CFM is 312.
312 * 1.24 = 387CFM = 26.7lb/min.
8lbs: 22.7 / 14.7 = 1.54 PR
70F increase in temp from pressure increase. 70% compressor efficiency brings 70F to 100F. this means 75 + 100 = 175F intake temp.
(535R / 635) (1.54PR) = 1.30 Density ratio
312 * 1.30 = 406 CFM = 28lbs/min
plotting 1.24DR, 26.7lbs/min and 1.30DR, 28lbs/min on flow chart makes me rethink about my turbo choice.
I am now leaning towards t04b 62-1 trim. This looks to fit better than any of the other compressors I have looked at. If anyone has any better ideas, lemme know. I'm pretty sure that my calculations are correct, and that I'm using them correctly.
Presently, it looks like at 8lbs of boost, w/ 1.30DR I can get at most 30% more hp = ~260. If I can lower the intake charge from 175 to 125(75 ambient) with intercooler thant I could raise DR from 1.30 to 1.41 resulting in ~22hp further increase from 260 to 282(basing 200hp stock). Of course Im not taking into account pressure drop from intercooler.
heres a site with some flow maps, specifially the one im looking at is at bottom.
http://www.turbofast.com.au/FlowTO4B.html
I've done my share of research in this subject, but if anyone knows better than I, feel free to share
