- Andover, VT
I went with .5" thk UHMW and added supports under the long spans (near the bottom and center). Grainger had best price when I bought. It has a high COE so make sure you account for thermal expansion in your mtg holes.
I recently made up some fixturing at work with UHMW that goes through a machine with temperature swings from room temp up to about 200°F. We calculated the 24" strip of plastic would grow about .300" with that change in temperature. Talk about crazy COE!
I like how you counterbored for hex head bolts. My original plan was to use flat head screws with mating countersinks, but I don't think my fabrication will be accurate enough to have the FHS's locate properly. And that's ignoring effects of temperature...
Looks like hex head screws or maybe button head screws are the way to go.
Rub rails are 1.75 dia x .188. Pretty sure about the .188 but I forget, def not .125. They're holding up fine and glad I added them. And, fwiw, the bends were done on the cheap HF pipe kinker.
Good work using the HF unit to do that. Its the perfect job to use that bender for as a slight kink/deformation of the tube is not life threatening like an imperfection in a cage could be.
A friend of mine has a JD2 bender with 1.75" and 1.5" dies. I've been looking for a reason to use it. He told me we can probably bend 1.5 x .188 wall DOM, but doesn't think we can do 1.75 x .188 wall.
Depends how you wheel, but I personally wouldn't go thinner than .188 on the 2x6. If I had a mostly overland rig then maybe .125 with the UHMW skids and rub rails.
Looking at those pictures really makes me think .125" will be sufficient on the 2x6 because they are mostly protected by the UHMW and rub rail.
Another concern of mine is the 2x6 being too large of a span to land a cage pillar on for only .125" wall.
B pillar cage tie-in doesn't exactly line up with an outrigger. I think ended up adding a support plate under the cage tie-in and welding it in.
I took some measurements the other day to plan how many outriggers to use and where to put them. I want the rear-most support to be against the leaf hanger, and the forward-most support to be 48" from there to match a 48" sheet of UHMW.
From what I saw, there is no good way to evenly space the outriggers with having one in place for a B pillar cage landing and also without interfering with seatbelt bolts, seat mounts, and my longarm crossmember bolts. I'll cross this bridge when I get there, but right now I'm thinking of using uneven spacing on the outriggers to snake them in between all the interfering components.
I did the rockers on my last XJ with .188 wall 2x4.
I used .125 wall 2x4 for my current XJ
The jeep gets used for overlanding and hunting but the most likely thing to contact the rockers is the high-lift jack.
I'd like to see pictures of all the mangled .125-wall rockers. I have not regretted cutting back at all.
That statement about the high-lift being the most likely thing to contact definitely drives home the reasoning behind using .125" on your rockers. Where did you butt the tube against? Looks like they stick out a bit farther than I would expect 2x4 to if put directly against the inner rocker. Are they braced to the unibody rails?
yes, I have braces (1x1 tube) in two places - one right below the A pillar, the other back by the C pillar. Fully welded along the pinch seam and to the "sill" under the doors to create a near-OEM look.
Ah, that makes sense. I thought some bracing would be necessary but didn't want to say that your method was ineffective because clearly its been working for you.
I made my own 2x6 rock sliders by welding (2) 2x3x.120 square tubing. This keeps the sliders light weight, but gives a .250 center wall down the length.
This is a pretty trick idea. Guess the only downside is you still only have .125" wall on the outer edge. I do like that very much though. Solves the issue of having a 6" span with a thin wall.
I just sent in a materials quote request. I quoted:
2 x 6 x .188 rectangle
2 x 6 x .125 rectangle
1.5 x 1.5 x .125 square
1.75 x .120 DOM
1.5 x .188 DOM
1.75 x .120 HREW
I quoted the different material sizes and thicknesses to get an idea of price variation between sizes. I'll let you guys know what the prices are.
My current thoughts are:
-2 x6 x .125 rocker
-five 1.5 x 1.5 x .125 outriggers
-1.5 x .188 DOM rub rail
-0.5 thick UHMW skin
Still on the fence about .125 or .188 wall for the rocker. Part of me says screw the 35 lb, go .188 for peace of mind. Other part says make it an efficient design. Material price will likely have a factor in the decision.
Might go 4 outriggers instead of 5. Gonna have to see where things line up. I don't want large spans (16"+) of unsupported UHMW
Might back the UHMW with .125 or .250 aluminum. Might not. We'll see.
