BrettM
- michifornia
I chopped my bed off
and am having a hell of a time figuring out how to wire up some tail-lights. My Chiltons and (downloaded) FSM don't seem to have the wiring diagram I need either.
Short Version
I got these
wired up and when I hit the blinker with no brake it lights up that side but does not flash. when I hit blinker with the brake that sides light goes totally dark for 1/2 a second then back to normal.
To make things more complicated, that is with the key in the ON position, if I put it in ACC things get weirder.
what's the deal?
Long Version
The lights I got are these:
The stock MJ configuration runs only 5 wires to the rear, two of which are ground and backup lights which we can ignore here. that leaves me with;
-blue (runs to both sides)
-gray/black (left only)
-brown (right only)
The blue I would assume be the Tail function. The gray/black and the brown I would assume to be the Stop/Turn function. In each tail-light there are 2 bulbs (exlcluding backup) each with 2 filaments. Both wires (blue and gray/black on the left, blue and brown on the right) go to both bulbs. So somehow these 2 wires are controlling 4 different filaments.
I just don't get it.
I ran through every possible tail/brake/blinker/hazard combination possible checking each wire with a multi-meter and it just doesn't make sense.
What I have right now;
Blue wired to Tail wires, Brown and Gray/Black wired to Brake/Turn wires. The Tail and Brake functions work perfectly, as do the hazard lights. The blinkers are what is all wierd :wierd:
Short Version
I got these
what's the deal?
Long Version
They are a 2 wire hookup; one for Stop and Turn and one for Tail. They ground through the mount.PM Stop, Turn & Tail Light Combination (V440l)
-brown (right only)
