NW99XJ
- Gresham, Or.
This run has been renamed....from the hangover run to the recovery run..... Myself and others (i'm sure) will do our best to explain.
The mornign started off brisk, windy, and dark.
Aaron (awesomexj) and Brandon (bmikes) with his dad, showed up at my place on time.
Mike however (bhmike) was a no call-no show. I gave him much grief via text, and left a horrible voice message in hopes he'd figure things out. (nothin but luv for ya man!)
The four of us hit the road, The presidential motorcade was underway!
We made it to Banks just as the sun started to crest the horizon.
We pulled into the Shell station to top up the tanks and ran into Jason (crazymoose) as he was filling up...
I had a half-a-tank left so I figure I'd top off before heading up the hill.....
This is the point of the day in which I realized I had forgotten my wallet at home. GOOD TIMES! (i have never done this!)
Aaron was kind enough to kick $20 my way to top off my tank, and we were on our way.
We got to Rogers right about 8:50 give or take, staged, and met up with those who straggled in. Kenny, Jon, (bronzewyrm) the other Jon,(98fivespeed) and Larry (demonoid) arrived within minutes of each other, and we finished airing everyone down and got our running order and trail routes set.
THE PLAN:
To run Powerline and make our way to Archer's, with maybe a stop off at Hoodraiser and Hoggsback.
WHAT HAPPENED INSTEAD:
Jason had planned to meet up with his buddy Jarod up there, and unbeknownst to the rest of us, HE had a couple buddies tagging along. Another XJ, A Nearly stock K5 Blazer, on street tires,...and a 2WD Toyota Tacoma P/U.
Somehow, they got up front ahead of us, and managed to get partially up the first section of Powerline, before low-and-behold....the bronco and tacoma had problems making it up. After a good 30 min or more sitting there wheeling over the CB, an Executive decision was made and we all (minus Jason) backed out of Powerline to bypass and regroup. Once back onto the logging road, Larry got the bright idea that this would be the most opportune time to attempt the very-first-time-disconnection of his factory front sway bar links.
I of course had the camera ready.
BPB Eat your heart out...... :moon:
After this all but brief rest and now well over an hour into the run, and not one rig in the group seeing more than 25ft of trail at best..... AND one rig of our group officially split away with the yotas and bronco, we made our way with the one non-naxja XJ with us to the second section of powerline.
I made it up to a good spot to park with no problems.
Bronzey was right behind me.
Brandon was right behind him, but made it no further than the first tight turn where the root-dig-out is. After a few runs at it he determined more runway was needed, but when backing up slid into a position where he could go no further without risking a flop.
Bronze came back down and hooked up to him and attempted to give him a tug.
Two tow straps, a half hour of sucking exhaust fumes, and a lot of pushing and grunting, Jon finally had to winch his way up with Brandon in tow.
Larry made his best attempt next. In doing so suffered some decent carnage.
He made it to the root-dig-out, but was stopped dead in his tracks (or lack there of) by a rock. This of course took out his tie rod, turning it into a pretzel. This was not the entirety of his carnage, oh-no.....
He also managed to taco his front DS wheel:
But the fun didnt stop there.....nope, why stop at one wheel when in one foul attempt you can fold YES TWO RIMS!
The rear DS wheel was also damaged beyond any trailside repair:
He decided that this was more than likely going to be the end of his attempts at Powerline, but not before parking his jeep to take one last look.....
His choice of location was not ideal.....
After the heroic display of Dukes-of-Hazzard like vehicle exit and entry his final decision was to turn around and head back out.
This too did not go without fail.
THE PLAN:
