TrueTrack install
Re: TrueTrac install
Just to get this thread back on track, the original question was: "does the Dana 35 in a '90 XJ use interior shims (as shown in most service manuals) or does it use exterior shims (as shown in most YouTube video's) for the carrier?"
I am only considering the following 3 options:
Spicer Limited Slip - $396.99
https://www.summitracing.com/parts/sdh-74210x
PowerTrax Grip Pro - $394.97
https://www.summitracing.com/parts/pwt-gt443527
Eaton TrueTrac - $477.20
https://www.summitracing.com/parts/dtl-912a569
Feedback on which of these 3 options would be best would be appreciated.
FWIW, I built a replica of a '65 Shelby Cobra like the one in the link below. I built a 400+HP SBF myself starting from a bare block, did all the suspension work, modified a Ford 8.8" LSD to fit, finished the interior, fuel system, brakes (including adding power brakes and ABS), electrical, steering and did all of the bodywork. I'm pretty sure I have the skills (and most of the tools) to replace a carrier.
https://www.factoryfive.com/roadster/mk4/
thx
Todd
Badass car! Got pics of yours?
Good luck w your build
If you want it to handle better on snow covered roads and dont care about wheeling then you dont want to install any traction aid in the axle. Spend the money on a good set of studded snows and winter wheels. 100 times better.
Feeling dumber having responded before, this is by far the best advice thus far. Snow capable tires are quite good. Pin the gas and they'll give their all not to budge.
If this is your only concern I agree with the above And I don't believe any traction device would out perform a proper snow tire.
Having driven with good winter tires, studded tires and and LSD I found that all were better than stock but when stopped at a light where the road is covered in ice, only the LSD would would allow me to accelerate at the green light like a regular road. The other two would always break traction at the start and had to be baby'd to get going or they would quickly slide sideways forcing the driver (me) to nurse the gas (or slip the clutch) to try to get moving.
Of course stopping is another matter. In fact, the biggest learning curve I found on an LSD is that its ability to accelerate under icy conditions gives you a false sense of security that quickly vanishes when you have to stop.
Tim,
I am going to add the PowerTrax no slip lunch box to the list based on your recommendation an will download the manual.
thx
Todd
Go with Eaton TrueTrac. I have a Chry 8.25 so no shim info, but a genuine Jeep Service Manual is only $7.95 from www.pacificcoastmanuals.com.
Note from OP: Since I can't delete this post I will simply add that the "No-Slip" version won't work. Looks like the only D35 option they have is to upgrade from a stock LSD.
OK, adding PowerTrax to the list adds some complexity. Which version would you recommend:
PowerTrax "No-Slip Traction System" - $443.21
https://www.summitracing.com/parts/pwt-92-0435-2725/overview/
https://www.powertrax.com/product-info/no-slip-traction-system/
or
PowerTrax "Lock Right Locker" - $327.81
https://www.summitracing.com/parts/pwt-2310-lr/overview/
Both have the advantage of being installed within the current carrier. The "No-Slip" variant seems to be their latest version without the ratcheting sounds.
The No-Slip functions more smoothly and is quieter. Same results from both versions at the tires.
A side benefit of any Lunchbox style locker is; if you don't like it, you can just as quickly and easily remove it and go back to an open diff.
