Monster3663
- Placitas, NM
I installed a Hayden Transmission oil cooler 526 kit that comes with a 650 cfm fan and pre-drilled mounting brackets on a front XJ skid plate . The cooler has 4 cooling rows and the fan can be setup to pull or push air. http://www.summitracing.com/parts/hda-526
First I cut and ground off the angle iron from the skid plate the width of the fan.
I had the old rusty skid plate sand blasted. I made some brackets that lowered the skid in the back by 3.5 inches I then flattened the front part to mount it onto the frame. I drew a grid of 1 inch squares for the vent holes.
The lowering brackets attached using a bolt from the sway bar bracket.
Plenty of clearance from sway bar. You can see the brackets that come with fan raise the fan up about an inch.
Approach angle is still pretty good.
Fan is connected to same relay as electric cooling fan with no issue. When electric fan kicks on so does trans cooler fan.
