scottyrock
- springfield,mo
91 xj 4.0L 4x4.
The lower transmission cooling line is leaking pretty bad on the rubber part of the line.I may fix it myself but have questions. Since this is a pressed fitting can I remove the rubber piece and replace it using radiator clamps? I am am just not sure how much pressure goes through the line and don't want the clamps to blow off.Or should I replace the whole line steel and rubber? Either way do I need to drain any fluid to prevent a big mess??
