Root Moose
- ON, Canada
I tried copying Tony_SS's transmission cooler install but have run into an issue in that either it didn't come with the correct/ same fittings or I'm doing something wrong.
Here's Tony's install:
http://www.naxja.org/forum/showpost.php?p=246080868&postcount=53
I got the exact same kit... kind of flustered right now. Serves me right for leaving mods to the last moment before a big road trip I guess.
Does anyone know what size/ description the compression fitting is at the top for the transmission return?
Jeep is a 2001.
Any help much appreciated.
FWIW, I installed the cooler on the driver's side of the grille opening. Two straps down from the header and one up of the passenger side of the cooler down the front cross-member and the strap holes line up with a random bolt hole in the cross-member. Solid mounting top and bottom and no drilling. Very flukey!
Jeep is a 2001.
