Lost_Wrench
- CO
New to forums, so thanks in advance for taking the time to read this and inform or educate me on these two 4wd systems.
So I have two Cherokee XJ's. One is a 1998 with (I believe) an NP242 Selec-trac T-Case. It has the part time and full time 4wd options. The 1996 has the NP231 which only has the Part-Time 4wd option.
I've owned several pre-97 XJ's with the 231 T-Case but the 98 is new to me and I am unfamiliar with it. It seems to work great in Full Time 4wd on snowpacked roads and getting up my steep snowpacked (plowed) driveway but the Part Time either isn't working properly or I'm not doing something right.
I decided to do a side by side 4x4 test of both Jeeps on a steep-ish unplowed road on the back of my property. Both Jeeps have good tires. My 96 XJ performed great and the 231 4wd system and T-Case was a beast as usual. It climbed right up and out of 10 inches or so of new snow on top of a snowpacked base with zero hesitation. 4Hi and 4Low worked as they should. The 98 XJ with the Selec-Trac didn't fare as well. In 2wd it just spun as expected, but then in Part Time 4wd it had without a doubt more traction than in 2wd (enough to eventually get me unstuck) but no where near what the 96 was capable of doing. Continuing the test in Full Time 4wd gave exact same results as Part Time, and 4low Part-Time did not feel like it was in 4wd at all, it just felt like 2wd low range. Is my T-Case in the 98 only working in Full Time mode where traction is only given to the wheel with the least traction? Like I said, it works great around the snowy county roads but in deeper unconsolidated snow forget it. "Part Time" in the NP242 should work the same as in the 231 right? So something isn't engaging correctly with my T-Case most likely? Either that or that T-Case sucks (unlikely). Any input appreciated.
Nick
Nick
