DurbElites
- Simi Valley
with the aw4 in my 95 xj my maual says to check the pump to see if its working you disconnect the pressure line and have your car in neutral and run your car for 20 seconds and by 20 seconds if the quart is not full of fluid you have to change the pump or the electronics inside. i preformed the test and in about 4-5 seconds the quart was overflowing is that bad that it pumps so fast or should i not worry about it?
