winterbeater
- Royal Oak, Michigan
I have used this method for decades when not changing the filter. It gets out just about all the old ATF.
Drain the pan and refill with fresh ATF.
Pull the cooler return line and connect it to a clear hose. Stick the end of the hose into a 1-gallon jug.
Start and idle the engine until 1 quart or so comes out and then turn the engine off. A helper is useful but not necessary, as the oil is not pumped out very quickly when idling.
Add the same amount of ATF to the transmission filler as what was pumped out.
Make sure to keep an eye on the jug so you do not over fill it.
Repeat the above until the fluid, in the hose, changes from a dirty color to clean. You will see the difference.
Top off the trans fluid, reconnect the cooler line and you are done.
Seal the jugs of used ATF and recycle them at your local auto parts store.
You do use a couple quarts more than what the FSM says the trans holds as the extra ATF flushes the old oil out of the torque converter.
If done right, there is nothing about this that can cause the transmission harm.
[FONT="]It is not the same as power flushing.[/FONT]
Hey, I hit quote on the other thread, then cut and pasted from there. Is that purtier Stewie? Thanks for the assistance in higher learning!
