xj88superjeep
- NJ
OH NO, THE DREADED ZDDP debate has slipped into a tranny fluid thread!!! Lets stay on topic...... LOL
High ZDDP oils are only needed in hi-performance motors with high valve spring pressures. Your stock flat tappet 4.0 will be fine with any SM rated oil. yes ZDDP was reduced due to three way catalyst poisoning from the volatile phosphorus in short chain ZDDP. Lubrizol has developed a High phos retention long chain ZDDP where the phos is less volatile, it is expected to be in gf-5 oils releasing in 2010. There have been many studys finding ZDDP didnt really help beyond 800 ppm, which is the limit on sm rated oils. also with the reduction of ZDDP came with increases in other anti-wear adds such as moly (MoDTC), boron, antimony, and others.
Is that all,Ive been running Amsoil for 35 years,8 of them in my brand new(2000) AW4.Many long distance trips towing my 3K LBS trailer,still runs as good as new,looks even better.The inside(s) are spotless,no sludge build-ups at all!I get a big kick out of reading these threads about which oil or tranny fluid to use..........:laugh::laugh::laugh: I have been using ATF+4 for almost 2 years in my AW4 and it runs great:moon: I also run Royal Purple in the motor and it purrs like a kitten with 50 psi oil pressure all day long!! :gee:
That takes all the fun out of it. I wonder if he is in the cam, engine parts, or engine rebuilding business, and needs more business, thus recommends SM oil, LOL. But I must wonder why they use to make high ZDDP oils for all cars until recently, maybe just to blow smoke up asses. LOL.
!!!1
Erm - can we try to keep this on topic? ZDDP concentration in engine oils is fuel for another discussion (and doesn't have so much to do with spring pressure as tappet style - organometallic additives are anti-scuff additives added to keep surface wear down on rubbing metal surfaces.
The reason for the decrease in organometallic content (particularly ZDDP) is because the oil blowby into the chamber results in catalyst poisoning, and a degradation of catalyst efficiency.
(We'd be able to eliminate the whole problem at a stroke if someone would release a roller cam and valvetrain for the AMC six - which is probably doable. We'd just need a cam ground for roller tappets - I think the ChryCo roller tappets could be made to work, as I recall, with little to no modification.)
This thread has gone awry, but since it's here, I want to learn... What about these?
Hydraulic Roller Tappet - Sold Individually (2.5L/4.0L Jeep Engines)
Sold here:
http://www.chicagoconnection.us/cat.php?log=Mopar&group=17&cat=155
Do they eliminate the "flat tappet" issue???
uh, these days a car dealer would do anything to sell you a new car.
no conspiracies implied, its do or die now.
and whatever you do to keep your jeep running reliably on road or trail, now is not a good time to fry a $1500+ tranny. Playing it safe is smart.
Dexron IV is likely the best choice of available fluids besides Dexron III, if your mileage is under 80k or so. I've done plenty of searching on this, and slippage is common with higher mileage AW4's when switched ATF+4 or synthetic Dexron. It's awesome if your transmission runs fine on ATF+4, cause it lasts longer than Dexron.
But if anything's funny, its someone who thinks the local domestic car dealer wants your vehicle to last...hahahaha. Now thats friggin fu-u-u-nny! They've long specialized in designed obsolescence, with disposable cars that puke out in 100k.
My dad has a 2004 Corvette, with a sealed transmission. No suprise, it croaked at 64k, being BABIED. $2400 to R&R. You think that was just chance that it failed? No, brilliant engineering, to fail right outside warranty.
So rest assured, the dealer want's your vehicle dead.
sealed as in it only has a dipstick???? no drain plug or pan to drop? or sealed as in no dipstick only a drain and fill plug similar to a manual?
the way things are today i couldn't tell you what a dealer wants, but i doubt what your saying. I highly doubt it if your suggesting the MFG wants that to happen.
not everythings a conspiracy
Personally I hate AW4 transmissions. So run whatever you feel like and hope for the best.
