jkmhb
- Huntington Beach, CA
The transmission cooling line on my son's '98 is leaking - on the side that goes by the steering box where the rubber meets the long metal tube.
So - can you cut off the metal crimp and get new rubber lines and double hose - clamp each end? Or do you need to spend the $$ to get an entire replacement with the metal lines and all?
Or - any other ideas?
