techno1154 said:Third gear do use overdrive,......... like a half gear between 3 & 4. I use it all the time in the city when the speed is too slow for 4+ overdrive. It shifts to overdrive when the speed is 3 to 4 miles slower. Also useful on hills to prevent gear hunting especially with large tires.
autocrossxj said:if the highway is flat with no noticeable hills then its ok to put it in od as long as the motor doesn't seem to be struggling at all, If it starts downshifting at all or loses speed alot just leave it in 3rd.
ihscoutlover said:I was told and now just saw the contradiction to flat towing an XJ. Check this out, if the transmission is in park, and the transfer case in neutral, how is the transfer case being lubricated? I was told on this forum that you would need to disconnect the rear driveshaft to prevent burnup of the transfer case. Whats the deal??
Jeff
Blaine B. said:So basically only pull the driveshaft if the front is supported and the rear is wheeling, unless you can put the transmission in neutral and not the transfercase?
Blaine B. said:Didn't someone say though if you put the tcase in neutral, it will lock all 4 wheels into neutral so therefore your front wheels will be trying to turn as well?
Not sure if that makes sense......but perhaps even though it is "disconnected" from the transmission by being in neutral, all 4 wheels become connected together in "neutral" mode?
Do you know what transmission temperatures you get without the cooler? With the cooler?xjtrailrider said:I tow with my XJ's(4 of them) all the time, all have been modified with large tranny coolers and tranny temp guages to keep up with the tranny. My bass boat wieghs 3100# and you will have no problems as long as you have trailer brakes on anything over 2500#.
Jim Mesthene said:Do you know what transmission temperatures you get without the cooler? With the cooler?
I do light towing in cool weather and am trying to determine the effectiveness of the stock cooler in my fairly new radiator.
I'll get a cooler if I have to, but most cars pull 2000 lbs. without an additional cooler; won't my !996 w/AW4?
Based on your experience towing with an XJ, I checked prices. Sure enough, it looks like $50 will get me a suitable cooler (and fittings etc.). That is cheap insurance.xjtrailrider said:A cooler is cheap insurance.....
