TRCM
- Newport News,VA
This makes more sense to me than the 20 responses insisting that I'm going to tow a 20,000lbs trailer regardless of what anyone says. Thanks. Makes me insane when you ask a question and 10 guys show up to insist that what you're "going to do regardless of input" won't work. If I listened to that every time, I wouldn't have a 350hp lifted XJ getting 25mpg (with roof basket and carrier removed).
.........any discussion about doing something a stock Jeep wasn't designed to do is always met with confusion and anger........
. As of this year, >5000lbs are exempt, and >5000lbs air care is required, and there's no way I'll pass unless I absolutely destroy my engine, so I'm stuck with the sticker on the door, so I guess I'll just see what I can do with 5000.
Talk about butt-hurt....
1) Well, the trailblazer comparison doesn't make any more or any less sense. But you will never see it that way because it is not what you wanted to hear. You claim it makes more sense cuz it is similar to your jeep. True, but our comparison of a regular truck to your jeep is also just as true & makes just as much sense because we were not comparing for similarities, but for differences
2) Sounds like the law up there says the same thing as the law down here...ya can't do it
3) the 'discussion about doing something a jeep wasn't designed to do' had no confusion or anger in it that I saw, we were answering your question simply, because it is not 'designed' to do it, nor is it safe to do
And as to doing what you want.......Your replies below indicated your intentions (altho they seem to have changed now that you know the law).
With the V8, I can't imagine 10k being too much, except perhaps on very long steep climbs
That said, I'm just using 10,000 as a baseline as I know my motor can deal with it
Also again, I'm not trying to pull 12,000lbs. I said that is the number that comes with my driveline so I know I can easily drag that much behind me.
None of us ever said you were gonna tow 20,000 lbs....you did:
I have an 05 LM7 5.3L with an 05 4l65e transmission. This combination is used in the base model rated at 9000lbs (for the 2005 year), upgradeable to 11,500 with tow package.
I don't care what you say I'm going to pull 20,000". I'm asking for real world issues I'd have to address to safely increase my towing capacity, and figure out how far I can push it (safely). Once I have a number, I'll either build a trailer to match, or if the number is too low, I'll worry about the tow rig some other day and build whatever trailer I want.
All quotes from YOUR posts.
