Tow Rigs :Fumoto Valve
AIbandit
Chico, CA
I don't know about your truck but It's annoying buying gaskets and torquing my drain bolt to spec every fricken time I change the oil (which is pretty often.)
I picked up a fumoto valve for my F250 PSD and it is by far one of the best/cheapest (19$) things I've purchased. I've had it for around 6 months now and it doesn't leak at all and makes oil changes much faster and cleaner. I got one with a nipple so I can run a hose to my drain pan.
I don't mean to plug the company this is just one of those things you will always wonder why you didn't do it sooner. I also don't recommend it for your jeep. :D
(no this is not my PSD)
I had one on my 91 XJ. Very handy when you have a engine skid plate that fills with oil each time you drain it; just run the hose out the access hole to the drain pan
