- Terra Firma
DO NOT USE THIS FOR TOW HOOKS!RichP said:Look at the tomken tow plate that goes between the two frame rails, Has provisions for mounting tow bar but can also be used as tow point with shackles. The other option is the front receiver and another option a front bumper with D ring mounts but thats going to run about $300 for that.
The Tomken tow plate is specifically intended for towing an XJ on pavement behind a motor home. It is not heavy duty enough to use safely for extraction. If you read the fine print, the version of it with the front receiver specifies that it is a light duty receiver.
