ive seen some guys in nissan 4wds that have turned their torsion bars up for a front end lift. I was wondering if this is possible on an xj or do they even have torsion bars??
Coils are a torsion bar that is wound in a helix to form a coil spring.
Both serve the same function but are used in two completely different ways. You can cheaply lift your coil spring front end by adding coil spacers on top of them between the spring and the body.
