Torque steer issues
Check your blinker fluid, if it isn't at the same level on each side in the back it can cause weight transfer when you use the blinker... you are using the blinkers, right?
Edit: it may also be caused by an uptight nut behind the wheel
I checked all that first. Thought for sure that would be it:greensmok
What do your drivers side control arms/ bushings look like? If they are loose and the drivers side tire moves backwards under acceleration and forward under braking, but the passenger side does not, it may feel like torque steer. The new tighter steering may just be amplifying an issue that you already had but didn't notice yet.
I'll check that in the morning when I check out the rear. Thanks
