iwannadie
- Gilbert, Az
Tank air pressure is pre-set to 155psi my manufaturer (non-adjustable afaik), and yes, my output pressure was set to 90 psi (or should i set to 120psi?).
Do i need to drain tank after every use?
(btw, it took only 6 min to pressurized tank from empty, which i'm happy with)
Thx.
The max I do is 90psi out or whatever the tools specifies which is usually lower.
I blast the air out of my tank to get moisture out. I also do not like leaving a full tank of air so I empty it if it is going to sit over night without use. I added a ball type drain valve which is way better than what came with my tank and makes emptying it much easier, I actually started a thread in the tools section if you are interested in that.
I say splurge and go with this impact gun, it's what I have and it is just total awesome.
I know someone selling one of these locally for $180 which is a killer deal. He actually has 2 and I am tempted to get a 2nd gun ha.
