WebDog
- Center City, MN
Thanks, still looking over my options. Leaning towards a performance rebuild from a shop in Phoenix.
I found a cheap and decent Campbell Hausfeld 62 pc set but it says Tool's Comsumption: 6.1 CFM@90 psi.
(Walmart at $79.88 shipped)
My question is, would i be able to power these tools with my new compressor with 5.5 SCFM @ 90psi rating?
Model Number: TL1069
Manufacturer: Campbell Hausfeld
Tool's Consumption: 6.1 CFM @ 90PSI
Thx.
Thx bro.
Now to find the right tools.
Any recommendation?
I agreed, but it's more like a starter/trail run since i've never used an air tool before and didn't wanna break the bank......still need some $ for my LA kit :smoker:.That's why I suggested looking at the tools first then looking comparing the CFM rating to the compressor you are thinking about buying ; ) . I still think a 5.5 cfm compressor is rather low but it's too late now. I am looking forward to a review of your air tools once you get them going. That first time I knocked lugs nuts off in seconds was awesome for me ha.
My air ratchet is still my favorite tool in the garage now. I also just ordered an right angle air drill, can't wait to get that today and see how it is.
Nah, i try to stay away from them if possible.Also stay away from harbor freight tools. At least for anything significant like impact guns and air ratchets. I've had to return an air ratchet twice from there. Plus there stuff is noisy. At least that's my opinion.
Lowe's has a nice Ingersoll Rand kit...$149 for a 1/2 impact, 3/8 ratchet and an impact socket set comes with it too. I just picked it up yesterday.
Quick question on a side note...but the answer may help the OP anyway. What's the difference in impact sockets? In other words, what makes one impact socket better than the other? Despite my harbor freight comment above I did by a couple sets of deep well impact sockets from them and I've been very happy. What makes one brand better than the other?
What would be the best cordless drill I could get for under $200 or so? Wouldn't mind getting air, since I want to get a compressor in the jeep also, but current living arrangements aren't favorable to it right now.
Looks good, but that gun does seem a little weak...
I totally agreed guys.stop buying air tools at wally world, the Campbell-Hausfeld (sp?) stuff they sell isn't that great. get an Ingersol-Rand gun somewhere. watch out for used tools too, they blow seals
I have one of those too.....works great for like $15.Its all about PSI/CFM,bottom line.I saw a few here mention drill/die grinders,most of those draw about [email protected] most DA's use more than most compressors can deliver.The best part of air tools is no heat,in my 40yrs of wrenching,Ive never seen ANY electric tool that wont burn up under "SHOP" use.As far as HF goes,I usually buy 4 of the electric 4.5" grinders at a time,since they tend to fail on a daily basis,but Ive never had an issue with their air products(oil them and they will last a long time).
Tank air pressure is pre-set to 155psi my manufaturer (non-adjustable afaik), and yes, my output pressure was set to 90 psi (or should i set to 120psi?).When you say the compressor is set to 90psi, is that the regulator air going out or the tank pressure? My compressor is set at 120psi tank pressure and 90psi at the regulator going out. Maybe that will help it from kicking on so much if your tank is only set to 90.
Don't forget after use to crack open the compressor drain and blow out the air/moisture.
Is this the kit you got?Lowe's has a nice Ingersoll Rand kit...$149 for a 1/2 impact, 3/8 ratchet and an impact socket set comes with it too. I just picked it up yesterday.
