IMO jigsaw/airsaw/sawzall makes the fender jump around too much and you end up with a really rough cut and warped fenders. cutoff wheel and patience will give you the best final outcome.
not if you pick the right blade and speed. I used a jig saw on mine. Taylor (the white one on the last page) followed my lines at mine. it came out perfect, no fender warping and no paint burnt. be sure to use a fine blade and plenty of lube. i finished it with an 80 grit sander wheel on the angle grinder after. it looks factory. the key is the lasers (my jigsaw has a laser lol) oh yea, and beer.
I couldn't get my 10'' Dewalt miter saw to unbolt from the stand so a 7 1/4'' circular saw worked for me! I like the 45* cuts, it kinda goes with today's box style designed automobiles!!
Here's how mine came out, with a jigsaw. cuts came out fine. i finished it with a flap disk on the angle grinder. no rubbing, 36" swampers.
no burnt paint, no bent, jumping fenders, the jeep didnt fall into itself when the doors were taken off. be sure to use LUBE and masking tape when cutting and take your time.
