To-do List
I haven't had a minute to work on mine yet between the clutch blowing up on the Dodge and Kate's wedding shower this weekend.
Hopefully be able to knock off the few things I have to do in May.
My to-do list:
-Register for NACFest
-Mount Fire Extinguisher
-First Aid Kit - Check
-Install CB Radio Not doing
-Install front locker
-Install ZJ tie rod
-Install SYE
-Install IRO Double Sheer Track Bar
-Paint stuff when the weather gets warmer - Check
My list got substantially larger from when I wrote the above. Should be able to get everything done in a few weekends though.
So do the rest of us
dude, im not even going to entertain you anymore.
another reason i got out of building something. the next couple years are going to causing me to divert my time elsewhere. you really dont have much to do though.
Stuff I will probably do:
-Sector shaft brace/winch skid - NOPE
-Double sheer drag link ends -TOO LAZY
-Change oil
-Grease stuff and tighten bolts
-Pull front cover to check Locrite and change fluid
-Finish building and swap in new driveshafts, current ones become spares - In progress
-Find a pair of spare 14b shafts and long side 60 shaft - Got the 14b shafts
Stuff I probably won't do:
-Get gauges working
-Get AW4 shifter working - NOPE
-Fix tires instead of just filling them every trip - Bought Creepies instead
Tow rig stuff:
-Bump timing
-Slightly bigger injectors - Pricing out a new set
-Fix dragging DS rear brake
What do you have to do for the shower? :laugh:
I didn't do a thing, in fact, I think I was working on my Jeep that day prepping it for FC!
I get it, just keep showing up to the events and don't drop off the face of the planet like some people do.
I have to go help her bring some stuff home since she just has her tiny car. That's about it.
Actually, I do have plans to go down to Gary's and fix my dipstick that day though. So I can check that off the list after this coming weekend :laugh:
You can't get rid of me that easily.
:thumbup:
Rebuild Durango Steering Box
Install UCAs and Front Stretch
Remove 1" of lift out of the front
Install 5150s up front
Brown Dog Mounts
Rebuild Front DS
Rear Brakes + Ebrake fix? Probably not...
Frame Stiffeners
Tube Rockers/Sliders
Since I already bolted 70% of the junk from the 2 xjs I've killed since last nac fest to this one I'm feeling confident but the list as it sits now.
-Skids
-CB
-Unweld my crosmember from the jeep
-zj disc brakes
-water pump, hoses, t-stat
-IRO tie rod
-steering box brace
-patch hole in the floor
-make doors removable
-balljoints
-pitman arm TRE
-aux fan
-rebuild track bar
-u-joints
I have accomplished nothing except making my list bigger. #BecausePOS
I'd like to do a flat skid plate before the trip and an oil pan skid plate, but I don't know if that's going to happen.
Otherwise its what I break/destroy between now and then wheeling.
mac 'at least two trips planned between now and then' gyvr
Finish up frame side 4 link stuff
Finish burning in everything on rear axle
reinstall rear brake stuff
get rear ride hight perfect
rear bumpstops
aqire frt coils
exhaust
rear driveshaft lenthened
finish up rear bob, bondo/paint/plexi
re install fuel cell
actually make nacfest with a vechicle of my own
Install 5150s up front DONE
Brown Dog Mounts DONE
Rebuild Front DS In Progress
Frame Stiffeners
Progress? Eh...
winch is mounted up, harbor freight power....
just added the axle seals, now they are leaking like a river, so my weekend will be taking it apart again....just had them apart too many times the inner seal is mad....
Use thicker oil and a bottle of stop leak
yeah I know thats a good short term solution. I have 85w 140 in there now i think... i dont know if stop leak and thicker oil is good for the auto locker, probably doesn't matter. Or i just replace the seals....I have had the axle shafts in and out allot, dealing with hubs, u-joints and various issues....
ah i did it anyway....
ill keep it going....
its like the flinstones in here....say hi to the muffler...
Finish up rear 4 link
finish up rear bob
paint stuff
put back of cage back together and add tube
buy and install frt airshocks
reinstall fuel pump and cell
not break anything Memorial Weekend
scratch all that stuff, not going air shocks and not wheeling this weekend. whats left.
tighten up rear 4 link bolts
install belly pan
install shocks
install seats
bleed brakes
paint and seal up rear body
hoping to wheel it once before then
