Rocketman
- Bolingbrook, IL
Brad and Gil...
Doing the D44 build thing and need some advice. Was considering the JKS short shock mounts for better clearance. I don't weld or torch. Before taking the new ones to someone to weld on, I'd like to save some work and cost/time and cut the old ones off. Is the best way to torch off what you can and then grind off the remains? Is there a better way to clean up the old mounting points? (plasma cutter?) I'm having the housing blasted so it will be all nice and shiny. I'd like to get off the old mounts before getting it cleaned, or should I just wait?
