Cruzin Illusion
- Commerce City, Colorutah
I thought I would just let everyone know about TNT HP44 Conversion Kit. I spoke with Bob and Matt from TNT about a HP44 Weld on Truss and they told me they were in the works on one. I am building a HP44 out of a 1976 Ford F-150. After preping the axle the Kit took appoximately 1 1/2 hours to install. Everything is properly located the only measurement you will need is pinion angle.
1. Surgically remove the weld-on wedges off of your Dana 44**
2. Set differential on jack stands
3. Set appropriate pinion angle (prop in place)
4. Drop truss on housing set its top parallel to the ground
5. Tac truss in place
6. Drop coil buckets on tube, slide against truss on either end
7. Set coil bucket angle with top parallel to the ground
8. Tac coil buckets in place
9. Set left and right lower control arm brackets on the housing per install instructions
10. Tac LCA mounts in place
11. Flip down mask, burn it home
If you have any questions feel free to ask.
Tom
Tom
