TNT Bumper, BOR springs, Tube Doors
fireLt.
Craig Colorado
TNT Bumper, BOR springs, Tube Doors, Currie Anti Rock Sway bar
All parts fit a 96 XJ
TNT Customs front bumper with the inner steering box brace. $400
http://www.tntcustoms.com/bumperfrontxj.aspx
1 Pair Big Offroad 4 1/2'' flexy springs. These are the best springs I have ever owned on this rig. 2 seasons of wheeling on them, maybe 2k miles total. Poly bushings. One of the bushings is slighty disfigured from being too close to the tail pipe, cosmetic damage only. $350
http://www.bigoffroad.com/products-page/
Set of front and rear Warrior products tube doors. $400 for the set
http://www.quadratec.com/products/pr...1100,1150,1200
Currie Antirock sway bar. 2 seasons use. $300
http://www.currieenterprises.com/cestore/antirock.aspx
All of this is located in Craig Colorado. I get to Arvada several times a month and can deliver!
Thanks.
He's doing some serious chopping. Saw the progress the other day..... It's actually starting to look a lot like a YJ......:puke:
Those BOR springs just became collectors items......... :shhh:
the tube door link isnt working, and i see there is 84-96, and 97-01.
anyone know what the difference is? and can they be modded to fit the 97+?
The hinge and latch designs changed on the '97+ rigs. Fairly significant issues to mod these, but if you've got a welder and a grinder you could make 'em work. The latches on the tube doors are meant to clamp down on the single stud striker the earlier XJ's use. The '97+ have that u-bolt looking striker that is a smaller diameter - the latches would clamp on the outside edge of the newer striker, but would rattle as it won't clamp tight.
Does that make sense?
I think Warrior products sells both versions of the latches and they bolt on the doors, it's the hinge differences that would be more difficult.
$300 for the bumper or $300 for the tube doors. I'll make you a deal if you want them both. i'll be in Arvada Feb 3,4,5.
Thanks Yella.. yeah that's too much work for my blood.
