TJ Rubicon d44 shafts in an XJ?
Goose_XJ88
Sacramento, CA
So I've done a little research and I would like to get the opinion of the NAXJA members. I found an aftermarket site that sells axle shafts with the same part number, just a different bearing options to be pressed on.
So can TJ 44 axles be used in an XJ 44?
Found a guy selling a pair of 30 spline shafts on Craigslist but want to be sure that theyd fit.
http://www.rwkhaussupply.com/magent...chromoly-axle-kit-for-rear-dana-44-tj-xj.html
Probably the best thing to do is call Robert from the link that you posted. He is very knowledgeable and can help you out.
I sure hope they do as I have had a set for spares,several years now.... Be sure you use XJ retainer plates. Or If set up with rear disc brakes..the correct retainer for your application.
