:confused1 OK, I'M NEW AND I DID A BUNCH OF SEARCHING B4 POSTING. WORSE YET I'M A YJ OWNER. (WHERE'D EVRYBODY GO :jester: ) HERE'S MY PROBLEM, TITAN SAYS WITH THERE 4.6L ALL I HAVE TO DO IS RETARD MY DISTRIBUTOR A FEW DEGREES, THROW IN FORD 24LBS. INJECTORS AND EVERYTHING WILL WORK JUST FINE. WRONG!! I'VE DONE THAT PLUS A 180 T-STAT, NITRO BOX ON MY IAT (WHICH HELPED) AND I'M RUNNING 89 OCTANE, ONE TANK I ALSO THREW IN OCTANE BOOST. (DID NOTHING) HAS ANYONE HAD SUCCESS IN RUNNING A 4.6 W 9:1 COMPRESSION WITHOUT ADDING ANYTHING ELSE??? MY SYMPTOMS ARE AS FOLLOWS: I CAN LET THE JEEP RUN FOR A HALF HOUR OR JUMP RIGHT IN AND GO (IDLES QUIET AND PERFECT) TAKE OFF NO PROBLEM BUT ONCE I BEGIN TO DRIVE IT STEADY ANY LOAD CHANGE AFTER THAT POINT SUCH AS AN UPHILL OR MORE THAN A 150 RPM CHANGE ON THE THROTTLE (EITHER DIRECTION) AND ITS LIKE I OWN A POORLY RUNNING DIESEL. I APPRECIATE ANY HELP I CAN GET THANKS IN ADVANCE
my rigs info: 88yj converted to a 93. 4.6L, AX15, 4:10's & 35's purchased new pcm from jeep as well as crank sensor, o2 sensor, champion plugs (stock gap), cap, rotor, wires, fuel pump & filter. aftermarket includes map sensor, distributor, cam sensor, coolant temp sensor, 180 t-stat, c-force2 clutch, hollowed out cat converter, cat back exhaust 1 size larger than stock, nitro box on my IAT, stock air box w filter taped in. (cold air intake is coming) 93 dash harness, 94 engine harness (back half only) and no idea what year front half is. everything seems to work properly and everything is seen properly through pcm when i hook scanner up to it.
