Milisake_Racing
- Allegan, MI
Well, CPS has died. Last owner must have ran the wires too close to the exhaust. Two spots on the harness were melted and the third was bare wire that fell apart with just a little pull on it.
Got underneath to look where it is at and discovered that it is in the worst spot to get at for a sensor, sandwiched between the bellhousing and the floorpan/firewall junction. Any tips for removing and installing a new one? What tools did you use? Does dropping the front driveshaft help any? Should I just dremel out the floorboards
