i put a 99 engine in a 96 xj. changed the distributer, the engine wont start. will changer the dist change the timing. i get spark and am getting fuel.
somebody help me out.
thanks
Did you set the new engine up to top dead center on no.1 cylinder and point the rotor to no.1 onthe distributor before you put it in,or did you just rip it out of the old motor and slam it in?
got it started and it runs pretty rough. then i shut it off checked all fluids. tried to start it but it failed to fire. i started it 2 or 3 times prior and the check engine light came on.
any suggestions
thanks
