- In a strange land
I would still question the coil.
A weak coil might still give you a spark, but not be able to sustain that under load.
[/QUOTE]We're talking CPS here. It's a magnet alternator basically so produces VAC.
Sounds like a small but critical vacuum line leak at the MAP sensor or Throttle body side or one of the brittle lines going to the Fuel Pressure Regulator or AC controls in the dash or brake Booster, etc... CPS issue is usually a no start issue.1990 renix. Went to pass on highway. Kicked it into power mode. Punched it a little to pass. Truck died. Wouldn't restart. Trailered it home. Cleaned all grounds, unplugged and replugged sensor connectors a few times, checked cps, map, tps, temp sensor ohm, voltage. All to spec! Fuel pressure >31 psi and holding very well. Fuel filter not clogged. Cranked and it started! Ran a bit rough at idle but smoothes out at higher rpm's. Stalls at idle or if I whack throttle hard. Esp off idle. (Stalls) IAS does not seem to work as engine does not idle fast when starting. Checked dist. timing, seems ok. I cut ears off dist and brought cap a bit closer to rotor JIC. Thinking about opening up the holes on cps and pushing it closer to flywheel? Anyone use a wire brush, etc... in the hole while cranking engine to clean rust off flywheel? I'm in coastal Florida, btw and the humidity is destroying everything here! Can't figure this one out and I need my truck! HELP!![]()
