Lightfoot
- fort collins co
I bought my stroker about 3 years and 15k miles ago. I got it as a long block, so until now I had never been inside it. A month ago I started to suspect it was developing a rod knock under load. Last week it got significantly louder, and I decided it was time to pull the engine. After gutting the big iron pig, I found the front two main bearings worn pretty bad, and the teeth on the timing gears chewed to shreds. Everything else looked normal except for some scoring thanks to shavings in the oil. My best guess is that the timing chain was starved of lube and started tearing apart the gears. Shavings from the gears made it into the main bearings and the rest is history. My question is, if this sounds correct, how can I prevent it from happening again? The engine always had good oil pressure, 30+ at idle, and near 60 over 2500. What would cause the timing chain to run dry? and what can I do to improve its oiling?
Let me know what you all think,
Thanks
Lightfoot
'99, 2dr, 4.6, ax-15, 231, 8.8, hp30 wj knucks, 4.56's, 33's
Thanks
Lightfoot
