Hello all, hope your having a nice holiday season :flipoff:
I attempted the dreaded steering column fix. It took me lot's of research and I added a few new tools to my collection in the process. But all went well, was able to pull all 4 bolts and loctite them back in. Along the way I found a little steel clip on the floorboard, flat about 3/16" wide bent into a sharp V shape with a total length of about 1 1/4". I have no idea where it came out from, after looking at all of the pictorials on the net about this job, only 1 showed this clip sitting on a table but did not mention what it was. It was not the ignition buzzer clip.
So except for that clip I got everything back together the next day and everything worked great, tilt, blinkers, high beams, flashers, wipers and horn. Steering column was solid and tight. Went to start the Jeep and the key spun forward with no resistance at all and would not do anything, did not engage the starter.
I use my Jeep as a daily driver and I really need it to be running right now. Any ideas? Any idea what that clip is for? I can post a pic if that would help. BTW: I have the FSM for my 1989 Jeep Cherokee Limited and no where did it show this clip either.
I am on the way back down to rent the steering wheel puller, will check back in a bit, Thanks for any help you guys can provide!!
