the wishbone project-waayy too many pics-
hmmmm beez .. wanna tell me what you do for a living so i can get a job doin it too? 37 inch crawlers .. looks like 17 inch aluminum rims ...... not to mention all the other stuff hangin off it.. whew.. looks ......
now thats a question I can answer!
I used heims simply because they are smaller than JJ's....
I don't have much room to play with on the frame bracket.
string mock-up
just a thought that might help you out: get a bunch of aluminum welding rod and tack it together at the ends and try using that instead of string. That way you've got a solid mock-up device that you can also use to model your architecture and swing clearance.
-Steve
JnJ said:
Ok, next easy question. What happened to not wanting to weld to the unibody?
That's why he uses JB Weld for his suspension components. The JB won't damage the thin sheet metal. Besides, everyone knows he can't weld.
Beezil said:
where did I say I don't like to weld to the unibody?
I've welded to the unibody all ove rhte damn place....
damn drunk texans.
Don't make me go and dig up those old post.
JB weld? I thought mom did the welding?
