John D
NAXJA Member # 788
- Rockford, Mi
One small step for man, one big step for a jackass wrench turner.
LOL
Looks good :yelclap:
That's why I chose a Boss 289 w/C4 Dana 20 when I did my conversion to my 85 Cherokee Chief. That 2.8 was the biggest piece of turd ever made. Room was limited the Dana 20 t-case was on the correct side and the axles were full-size Bronco. I did this in 1990. Suggestions I have after my build go with a late made motor for the serpentine belt set up or convert it. I am presently converting my old 289 C4 drive train in the 85 to 1996 injection 302 w/AOD and 1356 Behemoth crawl box with either the Dana 20 or a 205. Dana 60 front and rear strictly for the trail. The cpu's on the 302 is a 2 wire set up so it's easy.Well, I got a lot done Wednesday.
1- Swapped the new trans and SYE equipped t-case in.
2- Got all the little things wrapped up. Cooler lines had to be reformed to fit the turbo 350 location.
Today I got the t-case shifter transfer bracket made, now it has support on the trans side. Linkage is adjusted and ready to go. The trans shifter linkage wasn't a problem.
The distributor rotor broke the tab when I was getting the converter bolted up, the firewall took it out when the engine was tipped back. I did have the cap loose.
Front driveshaft is in, the new rear shaft is now at the shaft stretcher and that will be in next week. The t-case is now full and a few quarts in the trans. When it's running the rest will go in.
On Friday's to-do list, finish the swap. Get the new upper control arms in and get the trans kickdown cable hooked up. I'll be able to at least lot drive this until the back shaft is in.
I'll get pics tomorrow.
