The to do list
xcalibur223
NAC VP
long branch, nj
Pickup new tow rig!!!
Buy/borrow/rent/steal a trailer
Oil change
redo alignment
install new leaf springs
install hood vents
install hood pins
install speed bleeders on all 4 calipers and bleed brakes
install new injectors
install throttle body
Hardest part is going to be a trailer
Replace seat bases (action: take pictures of driver's side one to document the failure from RocktoberFest)
Rebuild/reinstall CB mic extension cable/fix CB issues New extension built, need to test yet and reinstall
Get pinion seal on front axle replaced
Replace tcase rear output seal
fluid changes (oil/trans/diffs/tcase)
Rear driveshaft...DONE
Shifters...Done
Put interior back in and install new seats...DONE
Radiator...DONE
Reinstall front bumper...DONE
Relocate battery, welp, that led into having to replace the cargo area sheet metal...UGH?!?!?!?, DONE
Rear shock mounts...DONE
Wiring...all in all DONE
S belt...found one and DONE
Reconnect steering lines...DONE
Gas tank skid...Done
Reinstall tcase skid
Fuel pump...Done
Rear brakes and bleed...DONE
Reinstall front ds..DONE.
Exhaust...DONE
new ac lines...DONE and charge the system
Reinstall hood and front clip...DONE
oh and inspection by April...not happening, at least not by April
Adjust shifter cables so engagement is better, because of new location...
I’m sure there is more that I’m forgetting...why am I building a new rig???
STROKER
My list is kinda short but time consuming
Figure out rough running/misfiring
Bump Stops (front and rear)
SYE and rear driveshaft DONE
Nut and Bolt the Jeep.
Figure out rough running/misfiring Not happening
SYE and rear driveshaftDone
My son just added:
Front and rear diff covers DONE
Upgrade the tie rod bar DONE
Upgrade the track bar Done
Lucky me!:bawl:
Set pinion angle and weld purchasing on rear axle
Grind all the TJ brackets off my Dana 30
Weld purchase onto Dana 30
Install Dana 30 lunch box locker and chromo shafts from my old 30
Drill the knuckles out on the new axle for my 1 ton steering.
Patch the crack in the frame
If I have time I'll address the rot at the rear shackle mount.
I knock one thing off then add 2 more. smh
-replace/rebuild all control arm joints DONE
-get new air oil separator for oba- DONE
- trim front fenders- DONE
-pick up some new tires- DONE
-new TB bracket, brace & 5.5 coils. DONE
-install tc skid DONE
-hydraulic assist DONE
-install rock sliders DONE
-build new steering and track bar DONE
-install new bumper and winch
-rear shock hoops DONE
Pickup new tow rig!!! DONE
Oil change
redo alignment
install hood vents
install hood pins
install new injectors DONE
install throttle body DONE
Pickup new tow rig!!!DONE
new upper control arm
redo alignment
install new leaf springs DONE
install hood vents
install hood pins DONE
install speed bleeders on all 4 calipers and bleed brakes DONE
coolant flush DONE
Hood vents will probably get done after NAC fest. Just waiting on some parts to build a new upper than align everything. Most likely going to try to rent a car trailer for the weekend unless anyone has one I can borrow or I can find a really good deal on one.
Shifters...Done
Radiator...DONE
Fuel pump...Done
Reinstall front ds order new rear ds and install...DONE.
Exhaust...DONE
STROKER
Actually took it for a test drive Saturday, drives like hell but it made it to the gas station and back...WOOHOO
Sweet!
Got my CB mic extension done a while back but haven't tested or installed it. Need to get going on those seat brackets, though, or the Jeep's not going anywhere...
Hello all, Registration will be up in the next day or two, we are having NACFEST so come 1 come all.
With this comes strict regulations that we must and will follow at the park and probably the camp ground, so lets show our best when the time comes.
https://www.facebook.com/150245635866/videos/233397187917344/
STROKER
Set pinion angle and weld purchasing on rear axle ---DONE
Grind all the TJ brackets off my Dana 30---DONE
Weld purchase onto Dana 30----DONE
Install Dana 30 lunch box locker and chromo shafts from my old 30--- HALF DONE
Drill the knuckles out on the new axle for my 1 ton steering---DONE
Patch the crack in the frame---- DONE
If I have time I'll address the rot at the rear shackle mount.---- HALF ASS DONE
JUST HAVE TO FILL THE REAR DIFF AGAIN, THE OLD OIL FELT TOO THIN.
Brackets have been cleaned up and coated in Eastwood Rust Encapsulator. Used Rustoleum rust remover gel (phosphoric acid) after hitting with wire wheel/flap wheel on dremel, it did a nice job. Even solvent-welded the crack in the tilt adjust lever (scored a tilting base for the driver' side).
Just have to get the driver's side one installed now. Anyone got a part number for the seat mounting studs for the 94-and-earlier seat mounts? The two front ones on my driver's side are pretty bad, not sure if they'll be usable. Open to bolts too, but would like recommendation as to bolt spec to use (grade 5? 8? 10.9?)
Shifters...Done
Radiator...DONE
Reinstall tcase skid...Done
Fuel pump...Done
Exhaust...DONE
Adjust shifter cables so engagement is better, because of new location...Done
new ac lines...DONE and charge the system Has now turned into a new compressor because there was a leak and...yup the fitting on the compressor was cracked....
Other than that it is done for now and ready to be used
STROKER
Driver's side seat bracket is installed - now my driver's seat is not only securely anchored to the body again, it now has "kung fu" tilt action too!. Got pics to document the failed bracket, just haven't pulled them off the phone yet. Got a sore shoulder from wrestling with the bracket to get it in the truck (think the front mount on the "new bracket" was bent rearward, took some wrestling to get it down on all four studs), but having a safely mounted seat was worth it.
New CB mic extension appears good (unlike the first one, no whine when I key the radio) and is routed back in behind the trim/headliner. Need to test against another radio, which I'll do either this weekend or next. Hopefully my only problem is was my not having wired that extension right (dummy me, I didn't use the shielded pair in the first one I built), or I'll be temporarily running another antenna cable by ziptying it to the passenger grab handles for now - not enough time to drop the headliner and pull the left-side cargo trim out right now.
Seals, I'm having done in the next few days(more efficient, and I'm not feeling like fighting with the pinion nut myself this close to the Fest), and I'm deferring the fluid changes until after.
Have not touched the Jeep since last year, shops full and works busy so off to the mechanic tomorrow it goes for some weird noises. Then I'll pick it up and strap it on the trailer.
So ready for stupid stuff saturday!
Sent from my SM-N950U using Tapatalk
Sorry to say there may not be a stupid stuff Saturday, maybe a toned down version. I won’t have a cage and I may or may not even have rocker protection.
This build is taking me to the wire.
STROKER
STROKER
O no worries, fully understand that.
Iv seen rich wheel backwards so anything's possible for stupid stuff Saturday hahaha
Hold my juice box and watch me go.
STROKER
Sounds like an invitation for someone else to take up the mantle (and no, not me - winning "most thrashed" once was more than enough)...
