goddamit i can't keep track of which thread i'm in.
I still say dynomax. If you want I will drive out to the cape and you can hear mine once my rig is back in my possession. Idk if it is just because I was used to a side dump cherrybomb but it is quite quiet. Granted I can't really hear it for now on the road due to aforementioned lack of interior components and excessive road/wind noise but hopefully that will be remedied soon.Alright, I think a few people missed my point/didn't read my post.
I want an exhaust system that ISN'T loud. I don't want something that is loud when I romp on it, or is really throaty.
This exhaust is to go on my daily driver. I have to drive it daily, and want to be able to hear myself think still.
Don't worry about that. Unless it has a hole rotted in it just take the heat shield off or throw a couple tack welds on it and call it a day. That's what I did and it seems fine now. If my welds didn't hold I was going to just pull it off and not look back like I did with my old car.I also should get a cat. The current one has a hose clamp around it from the PO because the shield was falling off.
Look mom no hands!
Strong arm part 4291 $22 at Advanced 10 min with a 10 mm socket/flat screw driver
Yeah ok so its super easy but after putting up with it hitting me in head for a couple months :laugh3:
No, I just needed a bigger hammer to get them off. Went out and got a 4.5 lb blacksmith's hammer and it came off in a matter of 15 seconds.did you take off the bolts holding the rotor on? most of the ones ive seen out there originally have a countersunk bolt with a philips head. the cars that i saw that have had rotors done before rarely had the bolts put back in.
its just the spiders
i made a little bracket and crap that worked OK enough. just make a little bracket and weld it to the ZJ arm that accepts the XJ cable.What e-brake cables will work for ZJ rear discs on a '98 XJ.
Is it any ZJ with rear discs? KJ cables?
My bro failed inspection for this. Trying to see how cheap they are if I can't get the cable clamp method to work on it. It doesn't work very well on my setup.
I'm so late on this but nooo I welded the spiders to the carrier big time. at least the c clips still come out and that shafts still come out![]()
