THe NAC Lots-O-BFG KO2 Thread
I got hungry at the shop so I went to go grab some food. Place I went to was closed so I went to the next open place up the street. I don't know what kind of food it is. The menu was all in some other language and the lady at the counter didn't speak a word of english. I just kept pointing at stuff and she would point at stuff and say "FIVE DOLLEH, TEN DOLLEH?" Anyway this food rocks, I think it's some kind of hispanic, maybe DB Dave's girlfriend can make me some.
poop on a rover
I'd say poop through the sunroof but it probably doesn't work and is permanently sealed shut with duct tape to prevent leaks :anon:
so I got my jeep home. looks like jordan pulled the distributor to replace it and never did and I dont know its position when he pulled it out. so now what
do I just put the cyl 1 TDC by feeling through the spark plug hole then make sure the timing notch is at 0 then instal the dist. with the rotor pointed at wire no.1?
That would be my first try. The distributor will engage a notch internally, so as long as you're "close" I think it should find its home ok. Worst comes to worst it runs like shit or not at all and you try again? I have to do this to my engine too.
Swap the motor
cry, then scrap the jeep.
Seriously though, turn the engine over with a breaker bar with your thumb over the #1 plug hole. If it tries to build pressure, you're on #1 compression stroke. Feel through the plug hole with a screwdriver (carefully of course) till you get it at TDC compression, then time the engine as you would normally.
THe NAC Lots-O-Post Thread
I'm residing on Long Island. Any things I must do while I'm here(6 months)
Who are you and what are you doing here?
They BOTH work mint and the drains are clean and clear. .!. :-D .!.
Are you absolutely certain that you do in fact own a land rover?
Because it sounds like it has none of the factory features.
Remember when I sent you a message last month and said my friend was looking for a place? Apparently my messages are meaningless to you :(
lol. my rear windows dont work, feel better? :laugh:
This is how people from NYC say "hello". :D
yes, sometimes. though i'm not from the city
ooohhhhhhhh now i remember.
One of my friends asked two of my other friends and I to be in his wedding by writing the invites on 40's of Old English. Most delicious invite ever.
